現在在試用LightUp
發現效果不錯
雖然質感還是沒有其他軟體漂亮
但是以付出的時間來說
我覺得很質得
目前遇到一個問題
如果使用skp直接存檔匯出檔案是一片空白
如果用LightUp裡面的頁面"still"匯出2d檔案一直存不起來
不知道有沒有人可以幫我解答一下
感激感激
Sunnie
SUAPP3.4
1万
Satan 温和而固执
tas_1985 2010-8-12 23:06:10
LU不是真正意义上的渲染,而是渲染UV贴图,再贴回模型
ytmfaaa 2010-8-12 23:25:50
我遇到过无法导出2d图像的问题,主要是su没有注册成功导致的,虽然能用,但是少了很多功能
只有重新装破解版的su才可以。
dfour 2010-8-13 00:05:07
回复 1# dfour
我看他的介紹似乎可以輸出tiff黨
但是我怎麼試都沒有辦法
(我的skp已經破解過了 應該是沒有問題吧?)
這是它網頁的介紹匯出方式,我照著做,但不知道是不是我英文太爛...怎麼都不成功!!!
Exporting Stills
While its all good wandering around our creations and experimenting with
lighting, we need to be able to generate images that can be used for presentations. Simple screenshots might suffice but at printed resolutions they lack sufficient fidelity
and generally look poor.
An additional feature of LightUp is the ability to generate very high resolution anti-aliased images of what youʼre seeing on screen. Press the Return key while using Tour Tool will pop-up the Capture dialog if it is hidden.
Simply choose you resolution and press “Still”. You will be prompted for a Savefile name to use. LightUp saves using the TIFF image format.
You can also choose to save the depth information for the image at the
same time. This will be saved as a floating point TIFF image with the addition “_depth” added to your filename. Depth images are commonly used by post-processing in applications such as Photoshop to identify the depth of each pixel so accurate montages can be created.
For example replacing the sky behind a building.
Another option is to use the cubemap generator. It will produce 6 square images centered on your current position from which you can easily create a Quicktime VR file to allow others to get a sense of a space interactively while retaining a small file size. Choose file naming to use appended names or appended numbers and press “Cubic...” and youʼll be prompted for a base filename/folder t which the six images will be saved.
Alternatively you can save the 6 images as a single vertical strip. The demo version of LightUp will watermark your export.
设计者中的小卒子
共享精神奖忠实粉丝核心会员宝石收藏家
佐佑 2010-8-13 08:45:49
:-?怎么用繁体 台湾的兄弟?
dfour
