出现一下错误提示:
加载文件错误 LibOnSurface.rb
uninitialized constant SUToolsOnSurface::TOS_DIR加载文件错误 LoaderOnSurface.rb
no such file to load -- /LibTraductor_20.rb加载文件错误 OffsetAlgoOnSurface.rb
uninitialized constant SUToolsOnSurface::T6加载文件错误 PaletteOnSurface.rb
uninitialized constant SUToolsOnSurface::T6加载文件错误 protrude.rb
(eval):33:in `require': no such file to load -- progressbar加载文件错误 RoundCorner_Common.rb
uninitialized constant RoundCorner::T6加载文件错误 ShapeOnSurface.rb
uninitialized constant SUToolsOnSurface::CODE_Rectangle加载文件错误 VRayForSketchup.rb
127: 找不到指定的程序。   - E:/SOFTWARES/[pro]setch up/Plugins/VRayForSketchUp/VRayForSketchUp.so加载文件错误 ZLoader__FreeScale.rb
no such file to load -- LibFredo6.rb加载文件错误 __loader.rb
uninitialized constant Traductor::Plugin加载文件错误 suAPPload.rb
(eval):7:in `initialize': wrong number of arguments (1 for 2)
请问各路高手指教啊!!!要赶作业了····拜托了!!!!!
SUAPP3.4
Tyburn 2011-3-22 08:39:01
缺少LibFredo6
VFS貌似XX没成功
68
许一世安逸
水墨纵横 2011-3-22 09:02:12
缺少文件,不过几个都是可有不可有的插件,应该不影响你敢作业。
16
夕日 2011-3-22 10:41:21
同上……缺少LibFredo6,可在紫天上下载!!
cqwto 2018-1-24 17:55:54
我的也是载入错误,并且好多。Error: SketchUp:1:in `eval' Error: SketchUp:1:in `eval' 载入文件 AN_optimal_path_array.rb 时出错 Error: #<RGLoaderError: RubyEncoder Loader - This protected script does not support version 2.2.4 of Ruby. Please contact the script author about this problem. Error code [07]> C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/io.rb:2:in `RGLoader_load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/io.rb:2:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/loader.rb:24:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/AN_optimal_path_array/AN_optimal_path_array-zh-CN.rb:2:in `<top (required)>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/AN_optimal_path_array.rb:35:in `load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/AN_optimal_path_array.rb:35:in `<top (required)>' 载入文件 CadalogBeamTool.rb 时出错 Error: #<SyntaxError: C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:21: syntax error, unexpected ',', expecting ')' ...pport_file ("CadalogParts.dll", "Plugins/Cadalog") ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:21: syntax error, unexpected ')', expecting keyword_end C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:296: syntax error, unexpected ',', expecting ')'                                 edges.push (beam_entities.add_line (startPt, endPt))        ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:306: syntax error, unexpected ',', expecting ')' ...eam_entities.add_arc (centerPt, xAxis, normal, radius, start... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:306: syntax error, unexpected ')', expecting '=' ..., radius, startAngle, endAngle)) ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:313: syntax error, unexpected ',', expecting ')'                                 edges.concat(beam_entities.add_circle (centerPt, normal, radius))        ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:313: syntax error, unexpected ')', expecting '='                                 edges.concat(beam_entities.add_circle (centerPt, normal, radius))        ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CadalogBeamTool.rb:362: syntax error, unexpected end-of-input, expecting keyword_end> 载入文件 cd_architect_extension.rb 时出错 Error: 载入文件 ChrisP_Repair_AddFace_DWG.rb 时出错 Error: 载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Bounce_on_face/CSR_Bounce_on_face.rb 时出错 Error: #<RGLoaderError: RubyEncoder Loader - This protected script does not support version 2.2.4 of Ruby. Please contact the script author about this problem. Error code [07]> C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/io.rb:2:in `RGLoader_load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/io.rb:2:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/loader.rb:24:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Bounce_on_face/CSR_Bounce_on_face.rb:8:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Bounce_on_face_loader.rb:9:in `register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Bounce_on_face_loader.rb:9:in `<top (required)>' 载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Distribute_on_vector/CSR_Distribute_on_vector.rb 时出错 Error: #<RGLoaderError: RubyEncoder Loader - This protected script does not support version 2.2.4 of Ruby. Please contact the script author about this problem. Error code [07]> C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/io.rb:2:in `RGLoader_load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/io.rb:2:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rgloader/loader.rb:24:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Distribute_on_vector/CSR_Distribute_on_vector.rb:8:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Distribute_on_vector_loader.rb:8:in `register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Distribute_on_vector_loader.rb:8:in `<top (required)>' 载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Mirror/CSR_Mirror.rb 时出错 Error: #<RGLoaderError: RubyEncoder Loader - This protected script has expired. Please contact the script author about this problem. Error code [09]> C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Mirror/CSR_Mirror.rb:11:in `RGLoader_load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Mirror/CSR_Mirror.rb:11:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Mirror_loader.rb:8:in `register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/CSR_Mirror_loader.rb:8:in `<top (required)>' 载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb 时出错 Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/nst/Plugins/RS_Window/Resources/Language/rubywindow_language.xml> c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/rs_window/resources/libraries/language_class_lib.rbs:43:in `initialize' c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/rs_window/resources/libraries/language_class_lib.rbs:43:in `open' c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/rs_window/resources/libraries/language_class_lib.rbs:43:in `Load_List' c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/rs_window/resources/libraries/language_class_lib.rbs:37:in `initialize' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb:53:in `new' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb:53:in `<module:RubyWindow>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/RS_Window/RubyWindow_Start.rb:34:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/RS_Window.rb:18:in `register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/RS_Window.rb:18:in `<module:RubyWindow>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/RS_Window.rb:10:in `<top (required)>' 载入文件 simple_building_generator.rb 时出错 Error: #<SyntaxError: C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ',', expecting ')' ...arch_floorplan (arr_main_input, arr_gf_input, arr_f_input, a... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ')', expecting '=' ...put, arr_f_input, arr_re_input)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ',', expecting ')' ...on_material (ground_floor_face, arr_ground_floor_pts_down[in... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ')', expecting '=' ...ex], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ',', expecting ')' ..._position_material (floor_face, arr_floor_pts_down[index - 1... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ')', expecting '=' ...own[index], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ',', expecting ')' ...n_material (rooftop_edges_face, arr_rooftop_edges_pts_down[i... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ')', expecting '=' ...oftop_edges_outer_mtl, mtl_fit)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ',', expecting ')' ...on_material (ground_floor_face, arr_ground_floor_pts_down[in... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ')', expecting '=' ...[0], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ',', expecting ')' ..._position_material (floor_face, arr_floor_pts_down[index - 1... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ')', expecting '=' ...ts_down[0], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ',', expecting ')' ...n_material (rooftop_edges_face, arr_rooftop_edges_pts_down[i... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ')', expecting '=' ...oftop_edges_outer_mtl, mtl_fit)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ',', expecting ')' ...terial (rooftop_edges_top_face, arr_rooftop_edges_pts_top[0]... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1948: Can't assign to false ..., rooftop_edges_top_mtl, false)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ')', expecting '=' ..., rooftop_edges_top_mtl, false)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ',', expecting ')' ...terial (rooftop_edges_top_face, arr_rooftop_edges_pts_top[0]... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1978: Can't assign to false ..., rooftop_edges_top_mtl, false)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ')', expecting '=' ..., rooftop_edges_top_mtl, false)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ',', expecting ')' ...rial (rooftop_edges_inner_face, arr_rooftop_edges_offset_pts... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ')', expecting '=' ...oftop_edges_inner_mtl, mtl_fit)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ',', expecting ')' ...rial (rooftop_edges_inner_face, arr_rooftop_edges_offset_pts... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ')', expecting '=' ...oftop_edges_inner_mtl, mtl_fit)  ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ',', expecting ')' ...osition_material (rooftop_face, arr_floor_pts_top[0], arr_fl... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2041: Can't assign to false ...pts_top[1], rooftop_mtl, false) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ')', expecting '=' ...pts_top[1], rooftop_mtl, false) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ',', expecting ')' ...osition_material (rooftop_face, arr_floor_pts_top[0], arr_fl... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2057: Can't assign to false ...pts_top[1], rooftop_mtl, false) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ')', expecting '=' ...pts_top[1], rooftop_mtl, false) # ===== UPDATE [08/08/2015] ... ...                               ^ C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2246: class definition in method body C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2303: class definition in method body C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2382: class definition in method body C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2392: class definition in method body C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/simple_building_generator.rb:2454: syntax error, unexpected end-of-input, expecting keyword_end> 载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer/core.rb 时出错 Error: #<NameError: uninitialized constant TT::Settings> C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer/core.rb:39:in `<module:Raytracer>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer/core.rb:33:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer.rb:39:in `register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer.rb:39:in `<module:Raytracer>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer.rb:15:in `<module:Plugins>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer.rb:14:in `<module:TT>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_raytracer.rb:13:in `<top (required)>' 载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell/core.rb 时出错 Error: #<NameError: uninitialized constant TT::Settings> C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell/core.rb:39:in `<module:Shell>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell/core.rb:33:in `<top (required)>' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require' D:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell.rb:39:in `register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell.rb:39:in `<module:Shell>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell.rb:15:in `<module:Plugins>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell.rb:14:in `<module:TT>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_shell.rb:13:in `<top (required)>' 载入文件 yaml_tree.rb 时出错 Error: #<NameError: uninitialized constant Psych::Visitors::Visitor> C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/yaml_tree.rb:14:in `<module:Visitors>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/yaml_tree.rb:6:in `<module:Psych>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/yaml_tree.rb:5:in `<top (required)>'
jimhahaha 2018-11-15 16:39:18
我也是这个问题,还没法解决!
0000ar
