Here's the Release Notes for the latest Enscape v2.9 Preview - Version 5.
Please refer to this article for instructions on how to download the Preview version.
What’s included
- New Features:
  • Vectorworks
    Export progress bar, video texture support, and View creation have been added to Vectorworks version.
  • 导出进度条,视频纹理支持,视图创建已经添加到Vectorworks版本。
  • User Account Licenses
    Login with your account, navigate to User Management option form the top right menu.
  • 登录您的帐户,导航到用户管理选项,从右上方菜单
    The following page will allow you to add a users email address and send out an invitation to join using the Add New and Invite buttons, upon which an email containing a link is sent out to the user to allow them to complete registration. They will then appear in the list as shown here below, where the license can be administered to the user by pressing the key icon, which will show the available licenses you may want to administer to that user.
  • 下面的页面将允许您添加用户的电子邮件地址,并使用add New和Invite按钮发送邀请加入,在此基础上,将向用户发送包含链接的电子邮件,以允许用户完成注册。然后它们将出现在如下所示的列表中,在该列表中,可以通过按下键图标对用户管理许可证,该图标将显示您可能希望对该用户管理的可用许可证。
    Each user is listed under their associated email along with the number of allocated licenses, and the status of the user. You can delete users using the trash can icon. This is a command to delete the user, so the user will receive an initial email warning that the account will be deleted in 14 days. If the user doesn't cancel the deletion in the following 14 days, they will receive an email informing them their account has now been deleted.
    Once the user is added to the list and a license is assigned, they can then log in to the associated account via the Enscape General Settings -> Licensing option by clicking on User Account (Login), and the License details will appear in the License Details section and Enscape will be unlocked for that user.
    每个用户都在其关联的电子邮件下列出,以及分配的许可证数量和用户的状态。您可以使用垃圾桶图标删除用户。这是一个删除用户的命令,因此用户会收到一个初始的电子邮件警告,该帐户将在14天内被删除。如果用户在接下来的14天内没有取消删除,他们将会收到一封电子邮件,通知他们他们的账户已经被删除。
    一旦用户被添加到列表和分配一个许可证,然后他们可以登录相关的帐户通过Enscape一般设置- >许可选项点击用户帐户(登录),和许可信息将出现在许可的细节部分和Enscape将解锁该用户。
- Improvements:
  • Custom Asset Library Improvements and Known Limitations
    We have improved our import capabilities again, covering more of the .gtlf, .obj and .fbx standards. The following limitations still persist:
    • Model files that are placed under file paths with Unicode characters won't work due to an issue in our conversion library
    • PBR materials in fbx files are unsupported
NOTE: These two limitations will remain in effect for the final 2.9 release.
自定义资产库的改进和已知的限制
我们再次提高了导入能力,涵盖了更多的。gtlf、。obj和。fbx标准。以下限制仍然存在:
由于我们的转换库中的一个问题,放置在具有Unicode字符的文件路径下的模型文件将不能工作
不支持fbx文件中的PBR材料
注意:这两个限制在最终的2.9版本中仍然有效。
We also currently have an issue where certain materials result in the model not showing up at all in the Custom Asset Editor preview viewport or the Enscape itself. This will be fixed for the final 2.9 release.
我们目前还有一个问题,就是某些材质导致模型在自定义资产编辑器预览视窗或Enscape本身中根本没有显示。这个问题将在最终的2.9版本中得到解决。
  • Screen space reflection quality
    Screen space reflection are now more precise, capturing finer detail and appear sharper.
  • 屏幕空间反射现在更精确,捕捉更精细的细节,看起来更清晰。
- Known Issues:
  • Certain textures applied as Type 'Bump maps' will result in the texture flickering in the Enscape viewport when changing its Amount value in the Material Editor.
当在材质编辑器中改变纹理的数量值时,某些材质应用为类型“凹凸贴图”会导致纹理在Enscape视图中闪烁。
- Notable Bugfixes:
  • Pre-processing of displacement maps - FIXED
  • Texture flickering when adjusting the Displacement map Amount slider - FIXED
  • Broken image rendering when Restmode is disabled - FIXED
  • 位移地图的预处理-固定纹理闪烁时调整位移贴图数量滑块-固定当Restmode被禁用时损坏的图像渲染-修复可以在下面的附件中找到更广泛的错误修复列表。
A more extensive list of bugfixes can be found attached below.
ENSCAPE超级讲吧原创教程
tas_1985
