Enscape软件下载贴
https://www.sketchupbar.com/forum.php?mod=viewthread&tid=345526&fromuid=3522
Released: 2020-11-04T13:07:12.2762934Z
Changelog:
  • Custom asset library
  • Offline assets
  • Video textures
  • Displacement mapping
  • User account licenses
  • Localized standalones
  • Batch rendering performance improvements
  • Custom attributes and confidentiality for BIM Track
更新日志:
定制资产库
离线资产
视频纹理
置换贴图
用户帐户许可证
局部独立的
批处理渲染性能改进
定制属性和保密BIM跟踪
Changes in Version 2.9
New Features:
Improvements:
Rendering
  • Improved quality of screen space results
    • Reduction of light leaking
  • Hierarchical Screen Space Traversal
    • Improved reflections and sharpness in close reflections
  • Prevent geometry leaking (common grass / carpet material issue)
  • Improved Specular GI via improved Blue Noise sampling
  • Improved Ray Traced Sun Shadows
  • Animations decoupled from Time of Day change
    • New continuous animation playback mode while Enscape in focus (not if BIM / Collab is in focus)
  • Improved RTX performance
    • All GI passes now running in Vulkan for RTX GPU's
Features
  • Standalone Executable Files
    • These are now localized which means they assume the OS language. If the language is not known, the fallback language, English, is used.
  • Enscape Asset Library
    • An additional 120 fitness themed assets
Changelog:
  • Rhino - Materials per surface
    • BREPS and poly-surfaces now allow sub-object selection and material assignment
Known Issues:
  • ArchiCAD 24 crashes when editing materials in Enscape Material Editor whilst an update is running
  • SketchUp and Enscape will crash when un-checking Explicit Transformation after changing the Textures size in SketchUp
  • Vectorworks and Enscape can crash when selecting the 'Existing Site Model Surface' option in Vectorworks
  • OpenGL context lost issue persists
  • Revit - Collaboration Annotation Issues are misplaced - mismatch between BIM Track and Revit
  • SketchUp can crash after closing it where the Collaboration Annotations Settings window is open
Bug Fixes:
Please find a list of the most common customer facing bug fixes attached as a .pdf below. We provide this list as a courtesy to our users and is not a complete list of all bug fixes during the development cycle. Please refer to the Bug ID if you have further questions regarding any of these.
版本2.9中的更改
新特性:
自定义资产库(更多信息)
Vectorworks支持(更多信息)
创建可用的视图和视图管理
可用的Enscape材质编辑器
ArchiCAD 24支持
对视频纹理的支持(更多信息见CAD的相关“材质”文章)
对位移贴图的支持(更多信息请参阅CAD的相关“材质”一文)
Enscape许可中心
用户管理(更多信息)
休息模式-启用/禁用连续动画(更多信息)
离线资产库(更多信息)
改进:
呈现
提高了屏幕空间的质量
减少漏光
分层屏幕空间遍历
改进了近距离反射的反射和锐度
防止几何形状漏水(常见的草/地毯材料问题)
改进的高光GI通过改进的蓝色噪声采样
改进光线追踪太阳阴影
动画随时间的变化而解耦
以Enscape为焦点的新的连续动画播放模式(在BIM / Collab为焦点的情况下不适用)
改善RTX性能
所有GI通过现在运行在Vulkan的RTX GPU
特性
独立的可执行文件
它们现在已经本地化了,这意味着它们假定了操作系统语言。如果这种语言是不知道的,备用语言,英语,使用。
Enscape资产库
额外120个健身主题资产
更新日志:
Rhino -每个表面的材料
BREPS和poly-surface现在允许子对象选择和材质分配
已知问题:
ArchiCAD 24在Enscape材质编辑器中编辑材质时崩溃,同时更新正在运行
SketchUp和Enscape将崩溃时,取消检查明确转换后,改变了纹理大小在SketchUp
当在Vectorworks中选择“现有站点模型表面”选项时,Vectorworks和Enscape可能会崩溃
OpenGL上下文丢失的问题仍然存在
Revit协作注释问题在BIM跟踪和Revit之间错位
在关闭协作注释设置窗口后,SketchUp会崩溃
缺陷修正:
请在下面的。pdf中找到最常见的客户面临的bug修复。我们提供这个列表是为了感谢用户,并不是开发周期中修复的所有错误的完整列表。如果您对这些问题有进一步的疑问,请参考Bug ID。
ENSCAPE超级讲吧原创教程
tas_1985
