各位大佬,请教一下,我安装了SU2021.1.299,然后安装Enscope3.0或3.1,均无法正常启动,启动时报错,不知有其他人有没有遇到,如何解决的,烦请告知,不胜感谢。错误日志如下:
2021.08.16 14:52:32.901 +08:00 [1] | INFO | SketchUp plugin starting...
2021.08.16 14:52:33.011 +08:00 [1] | INFO | AppDomain: SketchupPlugin
2021.08.16 14:52:33.011 +08:00 [1] | INFO | Enscape directory: C:\Program Files\Enscape
2021.08.16 14:52:33.025 +08:00 [1] | INFO | Enscape version: 3.1.0+51316
2021.08.16 14:52:33.026 +08:00 [1] | INFO | Renderer version: 3.1.0.2489-g2c997ef
2021.08.16 14:52:33.026 +08:00 [1] | INFO | SketchUp version: SketchUp Pro 21.1.299
2021.08.16 14:52:33.027 +08:00 [1] | INFO | Main window: D11410.skp - SketchUp Pro 2021
2021.08.16 14:52:33.029 +08:00 [1] | INFO | CLR Version: 4.0.30319.42000
2021.08.16 14:52:33.029 +08:00 [1] | INFO | .NET Framework Version: 528372
2021.08.16 14:52:33.031 +08:00 [1] | INFO | v4
2021.08.16 14:52:33.031 +08:00 [1] | INFO |   Client 4.8.04084
2021.08.16 14:52:33.032 +08:00 [1] | INFO |   Full 4.8.04084
2021.08.16 14:52:33.032 +08:00 [1] | INFO | v4.0
2021.08.16 14:52:33.032 +08:00 [1] | INFO |   Client 4.0.0.0
2021.08.16 14:52:35.929 +08:00 [17] | ERROR | System.IO.InvalidDataException: Signature could not be verified
   在 A.c2a51e6f1f658b1cdefec2fb479beea3a.c7cdbc3b70a5944e81ed50749a6be3bc4.MoveNext()
--- 引发异常的上一位置中堆栈跟踪的末尾 ---
   在 System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   在 System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   在 A.c385ce6d1c18668336b165d09d8ddcb5a.c19ca017de5da72ea491df7f8e806c4f0.MoveNext()
   在 A.c385ce6d1c18668336b165d09d8ddcb5a.c5d013671fb805979b4bddd0dd15644a3`1.MoveNext()
   在 A.c3cc4e5995bd0a4e6645d6e833542f8cd.c60bfcb16f618022a5e0833558a710252.MoveNext()
   在 A.c538aa85cfc0278ccd7a3abf7eb2a6c0a.c675d0df7cd94441f0e1ec9ed8c6336ea.MoveNext()
2021.08.16 14:52:39.307 +08:00 [1] | ERROR | Could not create StartupUserAction
System.Runtime.InteropServices.SEHException (0x80004005): 外部组件发生异常。
   在 A.c1a192c4a8f1551c6060cc3be3159557f.cf3c9dd759c8ad262f94c762f229dc578(c19c2bf3a2a926863c4b6d6a893357d76& c82738b034c555ef299c045c070908424)
   在 A.cf20a75dc311ba465c8c41f4caf698042.c071e33b8fd8415530172c684a472ab2d()
   在 Enscape.Gui.ClickTracking.StartupActionCreator.GetGpuFeatures()
   在 Enscape.Gui.ClickTracking.StartupActionCreator.CreateStartupAction()
   在 Enscape.Gui.ClickTracking.UserActionCollector.GenerateStartupAction()
Enscape官方许可证团购
drawpharos 2021-8-16 16:21:36
补充错误日志:
Target .NET runtime version: v4.0.30319
Target assembly: "C:\\Program Files\\Enscape\\Bin64\\Enscape.Sketchup.dll"
Target class: Enscape.Sketchup.Plugin.EnscapeSketchupPlugin
Attach to appdomain: false
Loading assembly Enscape.Sketchup.Plugin
Assembly::CreateInstance failed with hr 0x80131604: Unknown error 0x80131604
错误截图
错误截图
wudiming 2022-2-17 20:28:33
遇到了一样的问题,楼主有解决了嘛
啊超爱钓鱼 2022-10-9 16:20:28
我也是不知道怎么解决
drawpharos
