初来SU吧,主要是为了学习SU的二次开发,发些自己找的,学习小例子,以记。
下面的这个例子,是在SU中自动产生一些台阶,可以通过修改一些参数,改变产生的数量,阶高等,,
我也只是初学,如果有比我还菜的,有兴趣的可以跟贴,相互学习。
# # First we pull in the standard API hooks. require 'sketchup.rb'
# Show the Ruby Console at startup so we can
# see any programming errors we may make.
Sketchup.send_action "showRubyPanel:"
# Add a menu item to launch our plugin.
UI.menu("PlugIns").add_item("Draw stairs") {
UI.messagebox("I'm about to draw stairs!")
    # Call our new method.
  draw_stairs
def draw_stairs
  # Create some variables.
  stairs = 10
  rise = 10
  run = 12
  width = 100
  thickness = 3
  # Get handles to our model and the Entities collection it contains.
  model = Sketchup.active_model
  entities = model.entities
  # Loop across the same code several times
  for step in 1..stairs
  # Calculate our stair corners.
  x1 = 0
  x2 = width
  y1 = run * step
  y2 = run * (step + 1)
  z = rise * step
  # Create a series of "points", each a 3-item array containing x, y, and z.
  pt1 = [x1, y1, z]
  pt2 = [x2, y1, z]
  pt3 = [x2, y2, z]
  pt4 = [x1, y2, z]
  # Call methods on the Entities collection to draw stuff.
  new_face = entities.add_face pt1, pt2, pt3, pt4
  new_face.pushpull thickness
  end
end
把上面的代码复制存在一个文本文件里面,重命名为stairs.rb,放在C:\Program Files\Google\Google SketchUp 8\Plugins里面,再重新打开SU,在菜单项[插件]中可以找到Draw stairs,点击就能看到在SU中已经产生的结果。
sksf 2013-3-26 14:59:48
是在代码中修改参数吗?
300
忧郁王子
Rank: 10Rank: 10Rank: 10
ly871108 2013-3-26 15:17:59
厉害………………
leimikk 2013-3-26 16:36:59
  stairs = 10     台阶数
  rise = 10    升高量
  run = 12     运行次数
  width = 100     台阶宽度
  thickness = 3  台阶厚度
这些是定义相关的参数,修改这些值之后,保存文件,再重开SU,调用就能看到变化 了。
一叶刀虫 2013-3-27 23:28:07
会ruby的都是牛人
leimikk
