官網:http://www.maxwellrender.com/
Highlights
- Hair rendering: Introducing a new procedural primitive for rendering hair- compatible with the most popular hair systems (Shave & Haircut, Maya Hair, Max Hair, Ornatrix, Cinema Hair)
- Particle rendering: New procedural primitive for particles- compatible with the most popular particle systems (RealFlow particles, Maya particles, 3dsMax)
- Support for Vector displacement has been added
- Much faster (transform) motion blur
- Referenced MXS files: It is now possible to load references of MXS files in your main scene file, which are added only at render time, dramatically reducing export times especially for animations, and reducing scene transfer times when network rendering.
- Support for referenced materials has been added
- Scripting: Maxwell Render SDK now includes a standalone python editor and scripting examples
- Displacement: A second displacement algorithm has been added, much faster than the previous one
- Big improvements in image processing, filtering and aliasing: Enhances overall quality of the render, aliasing, sharpness, chromatic noise, dithering, etc and faster image generation routines. A new interactive parameter -sharpness -interactively controls the aliasing
- Advanced integration with RealFlow- a new smart workflow which allows you to handle RealFlow output and generate both meshes and particles in render time, saving precious disk space and greatly reducing export times.
Other New Features and Bugfixes
- New "Normal Vectors" and "Position" render channel
- Added support for new IES multiplicator parameter
- Separated Multilight controls for sun and sky
- Multilight now works with real units for sky- as it does for emitter
- New option in File menu "Import Multilight settings", that imports Multilight settings from an mxs file back into the scene
- Displacement + Instances is now possible
- Displacement + Motion blur is now possible
- Improvements in multithreading routines
- Added support for instances with motion blur
Network
- Improvements in error handling when the render process fails
- Improvements in stability and general robustness
- Improvements in performance, especially when rendering animation sequences with a lot of frames
- Option added for resuming jobs that are already finished.
- Improved algorithms for transferring dependencies
- Hidden command line argument -keeptempfiles for keeping temp mxi files after merging
GOOGLE翻譯:
- 頭髮呈現:介紹一個新的程序的原始渲染頭髮兼容最流行的發系統(剃須理髮,瑪雅頭髮,最大發,Ornatrix,電影發)
- 粒子渲染:新的程序原始顆粒兼容最流行的粒子系統(RealFlow的顆粒,3DSMAX,Maya的粒子)
- 支持向量位移已添加
- 快得多(變換),運動模糊
- 引用MXS文件:現在可以加載 MXS文件在您的主場景文件,這是僅在渲染時添加,大大減少了出口,尤其是動畫的時間,並減少現場轉移的時候,網絡渲染的參考。
- 支持引用的材料已添加
- 腳本:麥克斯韋渲染SDK現在包括一個獨立的Python編輯器和腳本示例
- 排量:第二個位移算法已被添加,比前一個更快
- 大的改進,在圖像處理,過濾和抗鋸齒:增強渲染,走樣,清晰度,色彩噪波,抖動等和更快的圖像生成程序的整體素質。新的交互式參數清晰度交互式控制的別名
- 先進的集成與 RealFlow的一個新的智能的工作流程,讓您處理的RealFlow輸出,並同時生成網格和粒子渲染時間,節省了寶貴的磁盤空間,大大降低了出口時間。
其他新的特性和錯誤修正
- 新的“法向量”和“位置”的渲染通道
- 增加了新IES乘數參數的支持
- 分隔太陽和天空Multilight控制
- Multilight現在漫天作為真正的單位工程,它為發射
- 新的選項,在文件菜單中的“導入 Multilight設置”,即從 MXS文件進口 Multilight設置到現場
- 位移+實例現在可能
- 位移+運動模糊,現在有可能
- 改進多線程例程
- 增加支持運動模糊實例
網絡
- 在渲染進程失敗時的錯誤處理的改進
- 改善的穩定性和一般魯棒性
- 在性能上的改進,尤其是當大量的幀渲染動畫序列
- 選項添加恢復已經完成的工作。
- 轉移依存關係的改進算法
- 隱藏的命令行參數 - keeptempfiles合併後保持溫度 MXI文件
下載位置:For Win 32位元&64位元
64位元
32位元
PLUGINS For Sketchup 7
http://download.nextlimit.com/maxwell2_dld/files/plugins/sketchup/Maxwell_for_SketchUp-2.6.0-rs-su7-win.zip
PLUGINS For Sketchup 8
http://download.nextlimit.com/maxwell2_dld/files/plugins/sketchup/Maxwell_for_SketchUp-2.6.0-rs-su8-win.zip
其他3D軟件PLUGINS請自行到官網下載
寂寞飯糰
婴宁 2011-11-5 16:50:58
回复看看,maxwell终于更新了,作为老牌的物理渲染软件再不更新可能就要落后了。
78
2012龙年春节团拜纪念邮共享精神奖宝石收藏家忠实粉丝热心助人奖核心会员
yangchongchang 2011-11-5 17:19:40
谢谢分享
linglong7 2011-11-5 18:43:05
谢谢分享 请问是破解版的吗
xiao8651457 2011-11-5 23:54:29
先看看~楼主辛苦了
wrx3120 2011-11-6 00:52:46
好东西求分享
74
宝石收藏家热心助人奖新秀奖
unclex 2011-11-6 03:00:08
和谐版么~~~~~
39
kuangji 2011-11-6 10:28:53
好,终于更新了!
133
heixing 2011-11-6 11:01:08
又来了..........
catkatty 2011-11-6 11:11:47
红宝石用户A
artzt 2011-11-6 13:30:51
牛逼啊,我需要
42
宝石收藏家热心助人奖SuBAR_CLT汉化团队
hebeijianke 2011-11-6 20:06:30
好像对SU的渲染器也出来啦
tmarch 2011-11-8 22:43:51
趕快下來試試 thx
wwxinshili 2011-11-9 16:15:44
谢谢分享.....
kylechen 2011-11-10 11:35:46
312321312312312321313132
63
宝石收藏家新秀奖忠实粉丝
yzh2 2011-11-10 13:49:03
我最喜欢的 mw {:soso_e179:}
63
宝石收藏家新秀奖忠实粉丝
yzh2 2011-11-10 13:51:51
应该是破解版吧,台湾的网速应该比大陆要快!
karl119 2011-11-10 17:16:42
好東西!!就是要感恩!!
WZF
352
习惯一个人
WZF 2011-11-10 20:16:04
看样子不错啊。
31
2012龙年春节团拜纪念邮宝石收藏家热心助人奖忠实粉丝荣誉会员Sketchup建模大赛 第三期 TOP5积极讨论奖
conners 2011-11-11 11:35:43
谢谢分享
chenkl
