https://www.sketchupbar.com/forum.php?mod=viewthread&tid=345526&page=1&extra=#pid63648142019-09-04Revit: Alternative asset placement
The default placement mode has been changed back to 'Place on active work plane'.
Vertical field of view support in camera sync and view creation
Enscape now handles field of view information correctly, if a CAD viewport specifying a vertical instead of a horizontal field of view is used
in conjunction with the camera sync or Enscape's view creation. SketchUp and Rhino are both affected by this.
Several settings related bugfixes
Several bugfixes of varying severity, affecting the settings and setting presets, have been implemented.
The Standalone settings UI has also been adjusted to reflect the current state of the settings overall.
Asset library popup bugfix
A bug leading to a misplaced tile popup in the asset library has been fixed.
The bug prevented favorite selection and access to the additional Revit placement mode.
Improved ray tracing quality
Compared to previous versions we’ve enhanced lighting calculations and accuracy of our ray traced reflections significantly: More detailed lighting in reflections, including objects casting shadows, texture maps and correct display of cutout materials, raise reflection quality. The same technology also increases the accuracy of indirect lighting in Enscape 2.6: Especially interior scenes with artificial lights benefit with less indirect light leaking and more pronounced indirect shadows.
Revit:另类资产配置
默认的放置模式已更改为“放置在活动工作平面上”。
垂直视野支持相机同步和视图创建
Enscape现在正确地处理视图字段信息,如果使用CAD视图端口指定垂直视图而不是水平视图字段
与相机同步或Enscape的视图创建相结合。SketchUp和Rhino都受此影响。
几个设置相关的错误修复
已经实现了几个不同严重程度的bug修复,它们影响设置和设置预置。
独立设置UI也进行了调整,以反映总体设置的当前状态。
资产库弹出错误修复
一个导致在资产库中出现错误的tile弹出框的bug已经修复。
该bug阻止了收藏选择和访问附加的Revit放置模式。
改进光线跟踪质量
与之前的版本相比,我们增强了光照计算和光线追踪反射的准确性:反射中更详细的光照,包括投射阴影的物体、纹理映射和正确显示裁剪材料,提高了反射质量。同样的技术也提高了Enscape 2.6中间接照明的准确性:特别是带有人工灯光的室内场景,间接光泄漏更少,间接阴影更明显。
ENSCAPE超级讲吧原创教程
Enscape官方许可证团购
1万
积极讨论奖忠实粉丝
szhktk166 2019-12-7 13:55:55
tas_1985
